Tyre pressures
peterdee
Sydney
Guard Mustang GT
Just a quick question: what tyre pressures are you guys running?
I have mine set to 38psi, is that a bit high?
Erez
Australia
White Platinum GT Manual
I had 37psi when she left the dealership, and I think it is way too high. If you look at the manual (Which is actually on the sticker at the driver side door) it says 32psi.
Zepboy
5LitresOfDemocracy
Perth, Western Australia
Richard
2016 Race Race Manual GT
The dash tire pressure monitor on mine reads 38, but when I've been to a server it reads more like 32-33.....
Copie
In a steel box
2017 Ford Mustang GT
32 is too low on a 19 inch rim, 38-40psi for better wear and economy
Bushranger
Australia, NSW Northern Rivers
Peter
Ruby Red GT auto fastback
Tyre pressure recommendations are for cold tyres, which is a tyre that has been stationary for at least 3 hrs. If you put 32 psi into a cold tyre then it will heat up to about 36 psi after about 10 minutes of driving. My dealership puts 38 psi in my cold tyres and I think that is too high as they get to 42 psi after I drive it. High inflated tyres might give better rolling and fuel efficiency, but may give less traction and increased wear in the tyre centre. Unless convinced otherwise, I will stick with the recommended pressure and observe the wear.
snake bite
Australia - Adelaide
Fords of course
My cold tyre pressure set at 34 and tends to run at 37 hot
