Twin Turbos on 13.5lbs of boost!
nastang87xx
Wisconsin
2016 GT350 Track Pack
You're stil on a stock bottom end???? :hail:
I always knew these motors would be stout. Sure it's borrowed time but still!
pro 5.0
Canada
2019 Mustang GT
The GT350 engine has a stronger block with no sleeves to crack and better rods and piston's than a 5.0L coyote, I wouldn't call it a ticking time bomb. Ford did say the motor was not built for forced induction due to engine harmonics of the FPC, and the 12:1 compression ratio, despite that many people are doing it and we haven't heard of one blow up yet.
TonyJ5150
TonyJ5150
Indianapolis, IN
2016 Shelby GT350
I eagerly await the results!
My high MPH for the day was 165.50.
Boost at about 8psi for 850 HP.
Traction was non existent in 1-3.
Going thru the traps at about 8k in 5th gear..
Would like to break 170mph tomorrow, but not sure what tweaks to do to make that happen..
SoCalTim
CA
Tim
Sold : 15 GT
Did you have a rear drag radial set up to switch up to?
My 600+whp Procharged GT had zero traction with MPSS tires.
TonyJ5150
TonyJ5150
Indianapolis, IN
2016 Shelby GT350
No, but will probably be investing in a set soon...
cozmo2312
Salt Lake City, UT
2019 Velocity Blue GT (current) 2017 Ruby Red GT350 (past)
do you have hood pins? does the hood flutter at those speeds?
TonyJ5150
TonyJ5150
Indianapolis, IN
2016 Shelby GT350
PencilGeek
Northern California
Robert
2017 GT350R HR278, 2008 BMW M3
Vbox ? If you don't have one, somebody at the event will. See if you can borrow it for your runs and get the files.
EF300
The Swamp, Central FL
2017 GT350, 2020 GT500 CFTP
So what traction control settings were you using? Was it spinning the tires with full traction control on?
ben@fatfab
Gold Sponsor
Indianapolis, IN
2011 Mustang GT Turbo
Tony let me make a few passes in the car this weekend so I will try and answer some of the questions.
Traction is non existent in 1st and 2nd gear. We do not have a Vbox to record speeds with.
We basically just rolled off the line with light throttle in 1st to get the car moving and pedaled 2nd gear to mostly full power then hammer down in 3rd. That seemed to net the best results. We need better tires and taller rear gear for sure. We had trouble trying to shift the car fast so that was slowing us down as well.
Thanks again Tony for letting me thrash on your car some this weekend and congrats on the top speed Ford for the day!
