Turn off factory EQ
trusaleen1
Central Valley CA
Todd
2016 GT/CS
i have the shaker pro audio (12 speakers including sub). Am i correct that there is a Forscan code to turn off the factory eq? Will his improve the overall sound? And what is the forscan code? I also plan on putting some poly fill in the stock sub enclosure.
2016 GT Coupe.
Cathul
Germany
Peter
Ford Mach-E
No need to change these settings if you are keeping the stock speakers.
19 GT Premium
Houston
Rich
2019 Mustang GT Premium
2016 GT Coupe.
Here you go:
RollOff Disable:
in the ACM tab
727-01-02 x*xx xx
0=EQ Selection #0, 1=EQ Selection #1, 2=EQ Selection #2, 3=EQ Selection #3, 4=EQ Selection #4, 5=EQ Selection #5, 6=EQ Selection #6, 7=EQ Selection
#7, 8=EQ Selection #8, 9=EQ Selection #9
change the noted *asterisk character to 0
krishelnino
Detroit, MI
Krishna
2018 GT Premium MT82 Race Red
Here you go:
RollOff Disable:
in the ACM tab
727-01-02 x*xx xx
Did you notice any difference after doing this ?
19 GT Premium
Houston
Rich
Yes. It seems like I'm getting a "Fuller" signal / sound primarily from my rear shelf speakers (upgraded) when volume is cranked up to 26 or 27. It sounds really good now.
FreedomPenguin
Dayton, Ohio
Donald
2017 Mustang Ecoboost Premium, 2013 Scion tC.
Don’t mean to hijack, but I am installing new rear deck speakers+ sub. I’m going to be tapping the rear deck speakers for sub signal.
If I use Only the disable roll off code, would it make the system sound pretty good? I’m leaving the main speakers alone.
Disabling EQ, Would this make stock speakers sound incorrect? If so I’m gonna disable using that code
Thanks!
Or am I reading this wrong, disabling bass roll off same thing as changing the eq? If this saves me not needing to buy a lc2i and still sounds good I’m going to do it.
Just thought a factory eq settings would sound the best stock settings could sound
