transmission identification aka spline count
Dean McQueen
Independence, Mo
Dean
2015 Mustang
Can i identify and determine a spline count on my 2015 GT from the parts numbers on the outside? My clutch has "disappeared" recently and i need to order one more suited for the Whipple forced induction but i need a spline count. Thanks for the help!​
robvas
MI
2011 GT
It will be a 23 spline unless it was upgraded to a 26 at some point. No way to tell without looking at it, unless you can see the splines through the inspection hole.
Dean McQueen
Dean McQueen
Independence, Mo
Dean
2015 Mustang
OK, I bought it with some modifications (however, as far as I know a stock clutch and only 12k miles) so I better see if I have a good number for the 1st owner or head for the inspection hole. Other than the obvious (3 more splines) is there any way to tell visually? I guess the better question is . . . Is it possible to count them in the inspection hole? I have a feeling, since I've never seen either one(23 or 26) it will be hard to tell. Either way thanks for the help.
robvas
MI
2011 GT
If it still has the stock clutch it still has the 23 spline input shaft
Dean McQueen
Dean McQueen
Independence, Mo
Dean
2015 Mustang
That's a very good point that I overlooked. : ) Kind of a "can't see the forest for the trees", I guess. Have a great day!!
