Traction/Stability modes questions.....
Gibbo205
UK
UK 2015 Mustang & BMW E46 M3
Hi there
So we all know that snow, normal and sport+ adjust the level of interaction from the ECS and TCS systems.
In race mode ECS is further delayed (more slip angle) and TCS is disabled.
However if you disable TCS via the switch, but say still select say wet mode does that mean ECS will still operate under wet mode parameters but TCS will be truly disabled?
I say because for instance this car is normal mode can get reasonable slip angles still, but TCS can be a little trigger happy, so a nice combination especially in the wet could be wet or normal mode but with TCS disabled. I just wondered if one could really get such combinations.
Of course if no one knows guess I need to go out and do some testing. :D
Pnasty
2016 GT/CS Ruby
when you change drive modes it overrides anything you did with the traction toggle. if you put it in to wet mode however, THEN disengage the traction I would imagine it would still disengage whatever you tell it to, or kick you out of wet mode.
Cati
U.k. Down sarf
2015 get v8 ucl mag grey & e93 m3 cp
you can back it all off with an SCT tuner if you want or on the old one hold button down f0r ten seconds to turn everything completely off
