Torsen differential + drag strip
NGOT8R
Adrian
2019 Bullitt
How many racers are running a Torsen differential at the drag strip? If so, what power level and what is your launch method? I’m hoping to make this work with my 2019 Bullitt which has every available rear suspension part I could put on it, save for removing the factory magneride. I also have a Hitmaster 2 Stage Clutch Hit Control System and will be on MT ET Street Radials. Any insight provided will be greatly appreciated. Thanks
NGOT8R
NGOT8R
Adrian
2019 Bullitt
How do you like the Hitmaster clutch control?
I haven’t done any launches since installing the Hitmaster, but the clutch engagement is 10 times better than factory. Before, the factory clutch used to have a high release point and with the Hitmaster it’s now perfect with a 1/4 to 1/2 way of pedal travel And much, much smoother. I’m waiting on a wheel stud kit to come in now. Once I get that in hand and installed, I’ll give the car an alignment and do some launches and report back. I do feel confident that it’s gonna be a big help to getting the car out of the hole much easier than it would without it.
