Today's dumb question oil drain plug? how do you?
RagmopInKona
CEO
2020 Mustang HHP
  • Thread starter
  • Banned
  • #1
Remove these? All my other vehicles have always had a bolt and washer, put a wrench on it, and boom.
How do I remove this type? I rather looks stupid asking than, break it and be S.O.L.
Thanks
Skye
≈39N
"Skye" Mach1 N2144
https://www.mustang6g.com/forums/threads/2019-bullitt-oil-drain-plug-removal.116852/
Here's a thread on two types, one which uses your fingers/pliers, the other, an extension. Turn CCW or unscrew, like you would a traditional plug.
And a video of the entire process, which will highlight the plug. Go to 4:52.
I've read multiple comments relating to re-installing and being careful not to over-tighten.
Some buy an aftermarket plug for the first oil change, so as to better control the flow of oil as it drains.
RagmopInKona
RagmopInKona
CEO
2020 Mustang HHP
  • Thread starter
  • Banned
  • #3
Thank you.
Rapid Red
Woodstock GA
Greg
I see you have a 2020, no tools required, Squeeze the tabs & rotate CCW, it will come out with 1/2 of a turn.
Be advised that 10qts of 5w flows FAST, I think most including me have been surprised with it. And not having the right size catch pan.
I am totally against the idea of the after-market plugs. Plastic pan, plastic threads, a metal afterthought plug.
Can be a point of failure at some time, stick with the factory part. When installing wipe the "O" ring with some oil as done with the filter.
I did purchase a spare in 2020 still in the wrapper.
