Tire fitment
FUN2RIDEFAST
Ofallon, Missouri
2017 Mustang GT Premium/PP
Today I mounted my drag radials on my 2017 GT PP. I went 305 /35 /19 on eleven inch rims. I put my rear 275/40 /19's on the front which should work fine but I've got a rub when making a fairly sharp left turn. It's definitely, by the sound, the fender liner. I was running 25mm spacers but removed them today. I'm thinking putting them back on the front will solve the problem? Thanks for the help.
MidwayJ
Dallas, Texas
Jay
2019 Mustang GT Coupe
It's all about the wheel offset. I assume you put PP1 rear wheels on the front? The offset of those is +52, which won't fit. The wheels sit too far inside and would typically rub the strut. The spacers will give you an effective offset of +27, which should fit unless you're lowered a LOT.
FUN2RIDEFAST
FUN2RIDEFAST
Ofallon, Missouri
Thanks. That's a great answer and I appreciate the reply. One other question. I've read people saying to use red loctite for the spacers but every instruction video I've seen uses none. The particular spacers I have call for a torque of 120 ft. Lb. Your thoughts.
MidwayJ
Dallas, Texas
Jay
I'm conservative and won't even use that type of spacer. It seems logical to recommend loctite as an extra precaution but I don't have any experience with them.
