throwout bearing
gsxr1300
MA
Jason
2023 Mach 1 2015 Mustang GT PP (Sold)
I will be changing my clutch and flywheel soon and thinking about changing the TOB also anyone have a part number?
gsxr1300
gsxr1300
MA
Jason
Thanks, So just replace with a stock one?
dubster99
Nor*Cal
2015 Ingot Silver GT PP
Stock is all you need. Grease it up liberally when it goes in.
gsxr1300
gsxr1300
MA
Jason
ok cool
why is it recommended then if I only have 10K on my original one?
dubster99
Nor*Cal
Because you're already in there doing the clutch, and it's a cheap part to replace.
Anthony 05 GT
Northern Harford County Maryland
2005 Mustang GT, 2015 Mustang GT Premium
Don't grease the bearing as it comes packed with grease. Clean the input shaft collar that the bearing slides on and apply a very light film of grease to the collar.
uglygun
kern co
66 289 2v, 95 Cobra, 05 GT, 15 GT Perf Pack
Bench bleed the hell out of that TOB before trying to stab the tranny back in. Bleeding those things can be a pain.
I went to a McCleod racing TOB on my 05 only to have it blow it's seals within about 2200 miles. Went through the proper indexing for the bearing to clutch fingers and everything should have been good. Noooope.
Went out to my car and had no pedal one morning, looked at front of car to find giant puddle on the ground.
Went back to a factory style TOB. The original had 120k miles on it when replaced. Should have stayed OEM style.
/edit
Important. If you buy an aftermarket clutch and use an OE style TOB it will probably have a concentric spacer included. Guess who didnt need the spacer for the aftermarket bearing and forgot to put it back in with the OEM bearing? Yup... got really good at removing and reinstalling the 3550 in my 2005 GT.
ALSO! Watch the thread engagement for the stock bolts for attaching the throw out bearing to the trans. If you put a spacer in there the bolts may only engage 2-3 threads and the casing for the trans is likely aluminum. Get spare bolts. Dont need to be anything fancy but be ready for it.
Anthony 05 GT
That was a 3650 in your '05 not a 3550. You are right about the aftermarket TB set ups. They will fail and usually quickly...more for race set ups. Been through a few of those, McLeod and Ram between 2 cars they all failed. I don't think there are any spacers provided for any clutch packages on the '15's, but I could be wrong. Like you said, I had to use longer bolts with a spacer on my '05
