It would have to be nearly all new, since there have been massive changes to the assembly as a whole. On top of that, since the old Torsen was added to the S197 late in its life, and the new one seems to have been assumed from the S550's inception, I'd bet (or hope, anyway) that its tuned and matched to the car better than the old one.Do you think the new torsen is redesigned or the same as all the older 05-14s?
Still 8.8 but much larger pinion bearing so while they are the same size the pinion shaft size has been increased significantly."while still retaining the 8.8-inch ring gear diameter"
I think the ring and pinion are the same.
