Suspension help
Mega
Lake Elsinore, CA
2015 Mustang V6
I'm planning on lowering my 2015 v6 with springs. I'm wondering if I purchase springs with 1 inch drop for the rear if my tires would rub. The size of my rear tires are 305/30/20. If they would rub what else would I need to purchase? Camber plates? Thanks!
Chef jpd
Brooklyn, NY
What offset, what wheels and what brand tires?
WhiteyDog
WOOF!!!
Manheim, Pa.
I'm lowered on an Eibach Pro-Kit running 315/35/20's in the rear +35 offset and I don't rub anywhere.
Mega
Lake Elsinore, CA
2015 Mustang V6
I can't remember what the offset is, the wheels are forgstar cf5, and the tires are Toyo tires proxies.
Mega
Lake Elsinore, CA
2015 Mustang V6
Thanks that does help out! I just gotta figure out what my offset is I can't remember what it is.
WhiteyDog
WOOF!!!
Manheim, Pa.
And so you also know, I didn't have to mess with the camber, either.
Roadway 5.0
Strassejager
New York - USA
2016GT PP 6MT
It sounds like I should be fine. I don't want to have to camber so I'll try to figure out my offset to make sure.
When you drop your car you will increase in negative camber. Don’t be afraid of this...it’s a good thing in the handling world (to a point). Focus more on ensuring your toe is correctly aligned and you’ll keep yours tires intact.
If keeping camber on the low side of factory spec is indeed your forte, then sure grab some plates for the front and, if you don’t like bashing your rear suspension, there are bits available to easily adjust rear camber too.
FranzVonHoffer
Houston
Black Mustang Base GT TP
I left the negative camber in and found tire wear is negligible. On the Michelin PP at least.
Coyote Red
Port Lavaca,Tx.
Alan
2016 5.0 Coyote Red
I use 1.4-1.5 neg camber front and rear and keep toe to 0.01-0.02 for a nice handling pony. Keep in mind when you set camber to 1.5 neg or more "You" must drive the car.
The Boss Mustang uses 1.5 neg from the factory, but "You" must steer the car. It feels great in the Twisty's and that's where I "Live" to drive!
