derieuz
The Young Fella'
- May 21, 2014
- Southeast Michigan
- 2015 Mustang GT PP
My coilovers blew out the OEM top shock mounts yet again, I believe it is from the shock bottoming out and their bumpstops not being as pliable as the OEM ones.
It appears to me that after the springs begin to settle, the shock travels gets reduced compared to when you first bolt the shocks on. The shock body is adjustable and I can adjust the height of the shock body.
Would it be okay to make the shock body shorter, and let's say leave a half inch between the top mounting holes and the top mount? I would then jack the control arm up a half inch and mount them, when the car is dropped the spring will compress fully and the shock will half much more travel.
Would I have any negative side effects from preloading the spring like that? I will be machining custom top mounts and mounting them normally when I make them, but I need to make sure they don't blow again while I am at school, I bought two replacements and now I have zero left.
