cvandenhaute
Agreed with that: summer tires when the weather is that warm will not have any issue there must be something else that caused it. I was reacting to all the post I saw stating driving a summer tire in the winter was fine as long as you don't gun it...I don't disagree with any of that. If I lived somewhere that the weather was consistently cold with the possibility of ice/snow/sleet on a regular basis I'd at a minimum go A/S, or go winter tires if it was someplace that had actual, consistent winters.
As it is, I live in Texas (and not in the panhandle where it actually gets cold), just as the OP does. And summer tires here are fine for the vast majority of the year when driven properly.
My issue was the OP having an issue when the weather was sunny and 55-58 degrees ambient. The road was likely even warmer. The Summer tires should have been absolutely fine. Instead he curbed it hard enough to make the side curtain airbag come out and blamed it on the tires instead of his driving. And even then claims the tires were only good for 60 or 70 degrees or above.
