I ordered an S&B 7/8" (22.2mm) ID filter it was slightly too big. I had to use a heater hose on the valve cover port to make it fit right. The correct size is the 5/8" (15.9mm) ID breather filter. You also want clamp on filters not push ins. Here is the link to the appropriately sized breather filters: http://www.ebay.com/itm/S-B-5-8-ID-...ash=item488e4db4dd:g:xyUAAOSw8oFX0wFs&vxp=mtrBreather size question: I ordered some cool looking ones(Ford Racing) off of eBay only to find out today they are the wrong Size. They are the 1.22" push-ins. What has everybody else used? I cant seem to find any that will work with the 1/4 turn system we have. I am thinking of trying to adapt these to the existing pvc and strip the guts out of it ala Whatdoyoufeedit.
When you gut the PCV you have to ether run it to a catch can or vent it to the atmosphere. You no longer can run it back to the intake manifold like stock or you will have more even more oil going into the manifold. You will also need to cap the port coming from the intake manifold to the PCV. You can watch my video and look through my pictures again and it will show that. Hope this helps.After some more thought.... Do you need to gut the pvc valve or just let it operate normally through the breather?
You don't have to delete the pcv if you do not want to (though it is a well worth-it mod). You can just vent the driver's side and add a catch can to the passenger side while maintaining stock connections. What is your goal? Are you trying to do the pcv delete or just wanting to add an air/oil separator? PCV's for these cars are cheap if you ever decide to go back to stock.Thanks Feedit. I grasp the process but did not know it gutting the pvc was necessary. My thought was not to gut it is I need to re-install for the dealer for any reason. I would think gutting lets it vent all the time and not gutting it would only vent when enough pressure was present.
Sounds like a plan. Post pictures of the finished project and once again feel free to ask any questions.Again, thanks for the advice! I am going to experiment with a breather on each side and go sans the catch can for now. I will see just what kind of mess that makes before I go all in on the catch can. I have ordered a tube from Fordguy550 and will also delete the other nipple on the stock intake tube. Nothing too fancy but the oil in the intake is crazy! I only have 300 miles as of now so I want to catch this early.
