I noticed mine does this when I first start the car.. not all the way to the ground though.Anyone else experience a sticky clutch, sticking to the ground and not coming up as i depress the cluch? First time happening i have 3000 miles on the car
Under what circumstances? High RPM shifting, at idle, ... ??Anyone else experience a sticky clutch, sticking to the ground and not coming up as i depress the cluch? First time happening i have 3000 miles on the car
Might have a little air in the system. A clutch system bleed might be worth a try.i was high rpm shifting when it happened
yeah if it happens again im taking it in, im from vancouver its burning hot out hereBring it in...not sure what part of Canada you are in, but it is likely that it isn't too cold there yet. As a fellow Canadian, I've found my older vehicles to stick in cold weather, but my 2015 V6 has yet to have any issues re: this. If it were me I'd go back to the dealer and/or contact Ford CA and express your concern; this should not happen under any circumstances.
