Step by Step Guide to Enabling Blind Spot Information System (BLIS) and Cross Traffic Alert (CTA)
Nightmonkey
Germany
Jens
2020 Bullitt
Whether you can do that is hard to say.
In general, however, it is always possible.
You have found the appropriate thread with all the information, let's go!
Nightmonkey
Germany
Jens
2020 Bullitt
Can someone help me with the part numbers for the black screws to attach the plastic brackets to the side panel using the sheet metal nuts?
I can't find the number here in the thread, feel free to bump my nose at it if I've missed it.
Magony15
Northern Illinois
2015 GTPP Base/Prem, 2009 Ram 1500
I have this number written down from when I installed mine. W502661S451. You can see the image on fordpartsgiant.com.
Nightmonkey
Germany
Jens
2020 Bullitt
Can someone please help filling the gaps and confirm for the BLIS part list?
DesignationConnector in wiring diagramFord part numberAmountManufacturerManufacturer seriesManufacturer part number
BLIS mirror glass, LH (LHD driver's side)-US-spec: FR3Z-17K707-G
EU-spec, heated: FR3Z-17K707-R
1Ford
BLIS mirror glass, RH (LHD passenger side)-US-spec: FR3Z-17K707-D
EU-spec, heated: FR3Z-17K707-Q
1Ford
BLIS sensor (left and right are identical)-2015-2017: EM2Z-14C689-A
2018-2023: JR3T-14D453-CC
2Ford
Bracket BLIS sensor-FT4Z-14D189-A2Ford
Screw BLIS sensor to bracket (optional)-W505563-S4374Ford
Clamp bracket to body (optional)-W714293-S4244Ford
Screw for clamp bracket (optional)-W705247-S4244Ford
Rubber grommet cable sensor into body-?1Aptiv / DelphiBlack Tape on Grommet12110414
BLIS LED mirror glass housing female terminalsC576, C676WPT-1197 (3U2Z-14S411-PFB)2JST AutomotiveJWPF02R-JWPF-VSLE-S
BLIS LED mirror glass terminal femaleC576, C676-2+JST AutomotiveJWPFSWPR-001T-P025
Door terminal pin maleC520, C626
Outline:
2+TE ConnectivityGeneration Y Connector System1924968-1
1924968-3
Door terminal femaleC520, C626Inline:
WPT-1544 (AU2Z-14S411-AMB)
WPT-1125 (AU2Z-14S411-AMA)
2+TE ConnectivityGeneration Y Connector System1456968-1
1456968-3
Mirror terminal maleC311-A3, C313-A3Outline:
2+MolexMX150 Sealed Series33000-1003
Mirror terminal femaleC311-A3, C313-A3Inline:
WPT-1425 (FU2Z-14S411-RA)
WPT-1482 (GU2Z-14S411-GB)
2+MolexMX150 Sealed Series33012-3003
Sensor terminal femaleC4369, C4370WPT-1434 (FU2Z-14S411-ADA)
WPT-1545 (FU2Z-14S411-ADB)
11+TE ConnectivityGeneration Y Connector System1456968-1
1456968-3
Wire FLRY-A black BK AWG22 (0.35mm²)--enough---
Wire FLRY-A purple-orange VTOG AWG22 (0.35mm²)--enough---
Wire FLRY-A gray-orange GYOG AWG22 (0.35mm²)--enough---
Wire FLRY-A green-white GNWH AWG22 (0.35mm²)--enough---
Wire FLRY-A blue-white BUWH AWG22 (0.35mm²)--enough---
Wire FLRY-A brown BN AWG22 (0.35mm²)--enough---
Wire FLRY-A black-blue BKBU AWG20 (0.5mm²)--enough---
Nightmonkey
Germany
Jens
2020 Bullitt
Maybe someone can also find out the Ford wire terminal repair kit part numbers for the connectors?
Nightmonkey
Germany
Jens
2020 Bullitt
Seems like W705247-S424 / FINIS 4106338 is the correct one.
Nightmonkey
Germany
Jens
2020 Bullitt
...making progress...
