steering assist fault
lisandra
mama smurf
Puerto Rico
lisandra
ecoboost PP non premium
car wont turn on and is giving me this on the dash. "Steering assist fault". Did it to me 2 days ago and after just reading codes with the access port it turned. Then again yesterday and after a few tries poof it turned on. But today theres no turning it on. The AP doesnt read the code, the only code that pops up is the lost communication with the AGS that usually does not affect anything in starting up but the steering assist code doesnt pop up. I tried disconnecting the battery for a while juuuust in case but since it isnt a wifi modem from 2007 it didnt work. Before I take it to the stealership, any ideas? anyone has had the issue?? faulty power steering module??
perfweld
Northern CA
2015 Ecoboost Mustang
My car messed up on me at the track one night after a run in the staging lanes. Power steering stopped working and it threw a code. I still drove it home with no power steering. It started working again 30 miles in, then I lost PS again the next day. It was under warranty, on the notes from the mechanic it was a ground wire that was installed against a painted surface. Why it acted up at a later date I dont know. I havent had an issue since for a few thousand miles.
cdenoma
Fort Worth,Tx
2016 EcoBoost Premium/PP
I dont know if this will help. But when I installed my UPR DVCC mine did the same thing. Check the ground strap on the passenger side strut tower as that was the culprit.
lisandra
lisandra
mama smurf
Puerto Rico
lisandra
no idea which ground was it?
perfweld
Northern CA
lisandra
lisandra
mama smurf
Puerto Rico
lisandra
anyone happen to have a diagram for the ground cables? I wanna make sure imm not missing one before going to the stealership
lisandra
lisandra
mama smurf
Puerto Rico
lisandra
well i disconnected and connected every possible ground I saw with no luck. stealership it is...
Elnegros10
Atlanta ga
2015 mustang ecoboost
Ecoboost premium
Mine had that happened Saturday it's at the dealership now.it will not turn on they switched the clutch pedal and didn't work.now they ordered the pcm and will try to start it when it comes back.ill let u know for sure!
lisandra
lisandra
mama smurf
Puerto Rico
lisandra
mine is going in friday, lets see what happens
perfweld
Northern CA
They had mine fixed really quick, just tell them about the ground, that might help them trouble shoot it. It was a ground wire on a painted surface in the notes.
lisandra
lisandra
mama smurf
Puerto Rico
lisandra
but they didnt tell you which?? I hate dealerships to death, If I knew which ground I could do this myself. Did they hand you notes? could you post a photo up? I could show them that
SidewaysMike
Somehwhere in the Med
2016 GT PP
You have no idea how much trouble you saved me!!!!
Thank you!
Mine did the same as OP described. Powered off and restarted the car, didn't change. Disconnected the battery, reconnected didn't change. Found the fuse, looked ok but I swapped it with another 5 amp just in case, still no change.
FOUND YOUR POST
Removed UPR remote mount catch can (which I've had on for 3 months/3,000 miles) BOOM all warnings gone, runs like new.
Don't know what to do now though, I had mounted it with the factory bolt rather than the 2 bolts and threaded piece UPR provides. Maybe that would make a difference?
RobBaker
MA
2015 Ecoboost, 6 speed, Performance Package in RR
I was getting the error message Steering Assist Service Required infrequently. Saw this ground as a possible issue. I disconnected the ground and reproduce the fault. Sanded the paint off below the ground bolt and the underside of the ground connection and bolted it back together issue resolved I bet. Thanks for the picture drudis I owe you a beer.
Ernie5_oh
California
Ernesto
2018 mustang gt
Did the error message go away immediately when you turned on your car ?
