Hello All Mustang 6G Enthusiasts,
You asked & Steeda listened ... we are happy to announce our revised Steeda Subframe Alignment Kit that will work in conjunction with the CB005.
The S550's subframe mounting holes are very large compared to the subframe mounting bolts.
Since there is a large difference in bolt and hole size, the subframe can be mis-aligned from the factory up to 1/2" left to right. The Steeda S550 Mustang IRS Subframe Alignment Kit is made from CNC-machined Delrin to avoid putting two dissimilar metals next to each other like the competition, preventing corrosion.
Delrin is also less weight than aluminum or steel inserts and therefore keeping performance in mind. The Delrin sleeves slide into the subframe mounting holes, and fill the extra space left between the subframe mount and bolt from the factory.
Our Steeda S550 Mustang IRS Subframe Alignment Kit guarantees that the subframe will be bolted to the same location every time it is lowered. Eliminating the need for unnecessary alignments.
Product Benefits
- Easy to install
- No permanent modifications
- Correctly align the rear end
- Aligns rear ends with BMR CB005 Kit
- No increase in NVH
- Made in the USA
Note: An alignment is needed upon initial installation, due to the fact it could have been mis-aligned from the factory and with it now being squared in the chassis, some adjustments might need to be made. This part is designed to fit with BMR CB005 Kit.
Best Regards,
TJ
Product Benefits
- Easy to install
- Made in the USA
Best Regards,
TJ
