- Mar 20, 2016
- Gulf Coast
- 2018 GTPP premium
- Banned
Does anyone know if steeda changed their minds about tuning cars with the GT350 intake?
If you are using the stock throttle body you can use your existing tune for the time being. Rev limit might be too low to take full advantage of it but it should run just fine until you can dyno tune it.I was hoping to get a revision from steeda so I can put it on next week. The local tuner I'm gonna use is busy for a while. It would be senseless for me to get a Lund tune or jdm and then spend 500 on a dyno tune.
Most custom tunes do not require a dyno tune at all. Lund and others can dial it in perfectly to the point that a dyno tune wouldn't get you anything more. Especially if it is revised after a road datalog. And when you factor in the cost, a custom tune is pretty much the way to go.I was hoping to get a revision from steeda so I can put it on next week. The local tuner I'm gonna use is busy for a while. It would be senseless for me to get a Lund tune or jdm and then spend 500 on a dyno tune.
This is true. Dialing in real time is the best tuning. A dyno helps get you there, but a full load and shifting can change things a bit.Most custom tunes do not require a dyno tune at all. Lund and others can dial it in perfectly to the point that a dyno tune wouldn't get you anything more. Especially if it is revised after a road datalog. And when you factor in the cost, a custom tune is pretty much the way to go.
Thanks for the info.If you are using the stock throttle body you can use your existing tune for the time being. Rev limit might be too low to take full advantage of it but it should run just fine until you can dyno tune it.
