Steeda camber bolts max camber?
strengthrehab
Houston
Ken
2016 DIB Base GT with PP
I have BMR SP080 SPRINGS, Stock PP struts and camber bolts. Had the car aligned today and Buddy said max camber was 1.3.
I figured it should be a lot more than that.
Anyine else?
wildcatgoal
@sirboom_photography
TBD
Recommend giving Steeda a call to verify, but I believe they should go to -2.5-ish. I'm not sure if those ratings are at stock ride height or if that matters at all.
strengthrehab
Houston
Ken
Seems like -2 should be easy.
Niz55
Us
17 GT350
I believe you need to slot the top hole of your struts .
Competition Orange
Columbus, Ohio
2017 GT350
I have the BMR camber bolts, Handling springs, and the same wheels (275/40 tires), and I could get -3.1 on drivers, -2.9 passenger for max camber. This results in the front wheels hitting the struts. I dialed it back to -2.6/7 and it clears the strut, BUT I'm getting inner fender liner rub/wear at lock (only noticed by visual inspection, never noise or feel.
I'll be dialing back to about -2.2 to utilize the entire contact patch.
strengthrehab
Houston
Ken
Your setup is what I was hoping for. I pulled out last alignment settings before today (no camber bolts) and things were still-1.5/-1.4. So something is wrong. Contacted my guy. I have a track day in 5 days and wanted this setup right. Grrr
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
For on track events -1.9 would be better much than 1.5. Some thing is wrong on the install,the cam bolt should go in the upper hole. You should be able to rotate the camber bolt and watch the hub move in and out. If you need further information pm your contact info.
