Steeda billet rear shock mount problems!
Bobombo
Houston, TX
Lan
Mustang GT 2018
Did anyone have problem with the billet rear shock mount worn out and started to make crazy noise when going over bumps?
FreePenguin
Ohio
Donald
17 mustang
I have them, but no noise. check your sway bars. make sure they are lubed and bushings are there. my driver side rear did it, but it went away.
I figured it settled in.
Bobombo
Houston, TX
Lan
Mustang GT 2018
I had these for a while now and not had a problem til now. It makes clunking/thuding noise everytime I go over bumps. It's been getting louder.
I took them off and replace with a spare one and the noise is gone.
The bearing inside is pretty loose. I can move the bearing inside the socket easily. I see all the dust and debris got between the bearing and the housing.
Do you know what kind of warranty does Steeda have on these?
If there is any Steeda tech out there could give me the info for replacing these. Thanks!
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
Please pm your contact info.
Thank you,
Steeda tech
