Stainless works
Classicnige
North Carolina
2019 Mustang gt
Will the stainless works redline cat back with performance connect bolt right up to looks longtubes?
Cashley
Space
Gen2
It should fit fine as lone as pipe is same. I have the redline on my car and i love it.
Logan@Lethal
Tampa, FL
www.lethalperformance.com
Logan
2020 GT 3.0L Whipple
If you are using OEM connect on both, they'll fit without an issue. If you go with a 3 inch connect, expect to have to either trim or weld in a small section as either company may define their performance/3 inch connect point to their catbacks to be a different spot. Example - many people use the Stainless Power 3 inch connect pipes with their SP headers and to combo it and truly use 3 inch Corsa Exhaust, you'd need to trim back the connect pipe.
Let us know if we can help out at all here at Lethal.
