Springs - Eibach & BMR
BoostedBen
Orlando FL
2017 Magnetic GT PP Premium
Hi all,
I have a 2017 GT PP, and recently installed the Eibach Sportline Lowering Spring Kit.
While I have to admit, the car looks fantastic, and i actually don't mind the extra feel to the road with the bumps and what not. But once I'm at or over 70mph, it's just to much. Very bumpy and not a comfortable ride.
Can anyone vouch for this? Should an alignment fix this?
I was also told that the Eibach springs don't go well with the factory PP shocks, and this could be causing it? Also heard BMR springs (not sure which ones) work great with the factory PP shocks?
I'm at information overload, if anyone has had similar experiences please let me know what you did! Thank you!
wildcatgoal
@sirboom_photography
TBD
Always need an alignment after lowing springs. And a good precise one, not one that just makes green colors on an alignment machine. With those springs, I'd get Koni Yellow or Steeda Pro-Action dampers. Steeda Pro-Action Fixed dampers will be perfect.
Good luck!
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
Hi all,
Also, check your bump stop clearance at curb. You need at least one inch.
This has been the culprit in many cases with the Eibach sportline springs.
If you have any further questions please pm me.
Steeda Tech
5OSONIC
San Francisco, CA
2016 DIB CS
This has been the culprit on many cases with the Eibach sportline springs.
Steeda Tech
Noob question. How do you check bump stock clearance at curb?
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Hi all,
I was also told that the Eibach springs don't go well with the factory PP shocks, and this could be causing it? Also heard BMR springs (not sure which ones - the right ones are SP080 or SP763) work great with the factory PP shocks?
All true. See additions underlined.
The lack of comfort is because the Sportline rates are a bit much for the stock shocks and struts and because they require the use of their bumpstops in the rate. It makes for a crappy ride no matter what.
rayban1
Rayban1
Seattle
2015 GT PP Premium Guard
I had the sport lines, never installed them, after seeing some reviews, especially this you tube post, sold them and went with bmr 089/082 which is the sp763 kit. This kit works great with pp shocks, and bumpstops.
BoostedBen
BoostedBen
Orlando FL
Thanks man, that helps a lot. Well, I don't want to go buy shocks and struts, already spent too much damn money already lmao. Looks like it's back to the garage to swap out to some BMR's that will work well with the factory shocks and struts.
BmacIL
Enginerd
Naperville, IL
Time well spent. Would recommend Steeda's billet rear shock mounts while you're at it. They significantly improve body oscillation/bounce and make the ride more supple.
Rebellion
Houston
2016 Competition Orange GT
One more thing, follow the BMR instructions and cut bumpstops accordingly. Most likely you don't "need" to cut them, but do it anyways (at least check it).
I would also consider the BMR CB005 while you're redoing the rear springs, doesn't take much additional effort.
solodogg
Orlando
2015 Mustang Ecoboost
Howdy neighbor! :)
All of the above information is true, Sportlines are really more about looks than ride quality/handling. I have the BMR SP089/082 combo on my EB, and the wife and I both prefer the handling/ride quality with these + 19x10 wheels vs. stock setup.
IMO, sell the Sportlines, and pick up one of the BMR setups. You won't regret it.
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
Love all the support guys!
[MENTION=33337]BoostedBen[/MENTION] - feel free to give me a ring tomorrow and I'd be happy to go over s few things with you.
