BCeagle08
- Jun 3, 2015
- Long Island, NY
- 2015 GT DIB PP 6MT Navi 401A.
Just got done installing the front springs on my car. Ran out of sunlight so I'm finishing the rear tomorrow. I had previously done spring installs on my 2000 mustang and my 2008 mustang, so I was pretty familiar with changing a McPherson Strut spring, but the springs on the 2015 were a little more difficult than my past mustangs.
1) The bolts that connect the strut to the spindle. Fuck. Those. Bolts. I busted out a full size sledge hammer after trying a rubber mallet, then a wooden mallet, then a metal framing hammer, then a mini sledge. It took 20-30 good whacks to get them out. Make sure you put the nut on the end of the bolt so you don't mushroom the bolt and make sure you hit dead on the nut so you don't deform the nut.
2) Spring compressor. You need to compress the stock springs a SHIT TON to get the caster plate off. Not a problem, but be aware of it. I only had the spring compressors you get from auto zone and advance auto parts - the type that are two completely independent bolts.
For whatever reason, the splash guard at the bottom of the strut is bigger than the ones I've seen on other mustangs. It gets in the way of the bolt as you tighten the the spring compressor and the bolt passes through the claw. You have to be very creative with the spring compressor location and you might need to put one "upside down" (i.e. the tightening nut side right up against the splash guard) and use an open end wrench to tighten it since an air gun won't be able to fit in there.
I was installing BMR springs and with one less coil than the stock springs it took a lot of trial and error to find a spring compressor location that didn't interfere with the strut. Be patient and don't get frustrated!
3) The retaining nut at the top of the strut is a pain in the ass. It has a nut inside the retaining nut that you are supposed to use to stop the shaft from spinning, but the retaining nut is buried so deep inside the caster and camber plate that you can't get a box wrench in there. Does anyone know how you are supposed to loosen and tighten the retaining nut without using a socket? If you use a socket, you can't hold the shaft using the inner nut so the shaft just spins and spins and spins. I had to use strap wrench to hold the shaft while I used a socket on the retaining nut.
That's my take on the front spring job. Anyone have any input as to how to make those trouble spots easier?
