Speedometer correction after gear swap
bhaunold
Va
Blake
2016 mustang
Hello, I’m getting ready to replace my rear end, I’m wanting to put a performance pack rear end in the car with the 3.55 gears. My cars currently a base model automatic with 3.15 gears. I was wondering if I will need to get a tune for 3.55 to have the Speedo be accurate again. Or since the wheel speed sensor is on the hub of the gears will affect the speedometer at all? Also will it affect shift points at all with stock tuning or if it’ll just rev quicker. Thanks in advance.
bhaunold
Va
Blake
2016 mustang
You’re speedometer will be a tiny bit off and you’ll accelerate a tiny bit faster.
When you say tiny are you talking about 1-3 mph? I’m okay with it being 5 off because I drive 5 over everywhere.
mavisky
Cumming, GA
Kyle
2018 GT350
S550 chassis cars measure vehicle speed through the wheel sensors. You can change gearing and the speedometer will remain accurate. Only changing the outer diameter of the rear tires will throw off the speedometer on these cars. This has been proven multiple times, but the incorrect information persists because this is the first chassis in which this is the way the speedo operates.
bhaunold
Va
Blake
2016 mustang
Thank you for confirming this. I’ve been trying to figure out what is true and false all day. Would it affect shift points at all?
Freedom
California
Whipple and ford have tools that adjust gear ratio. I think it’s called flare tool for whipple and the ford one comes with the performance pack upgrades.
I’m not sure what happens if you don’t adjust the ratio with these devices though.
mavisky
Cumming, GA
Kyle
2018 GT350
Perhaps slightly. Determining the ideal shift point to the most finite measurement is predicated on the amount of power delivered to the wheels at any given RPM. The gearing change can have an effect on this.
