Soler Performance Throttle Bodies & Throttle Controllers
Mike@SolerEngr
Gold Sponsor
Alabama
www.solerengineering.com
2015 Stingray, 2021 GT Premium
Soler Performance
Website: Ford Motor — Soler Performance LLC (solerengineering.com)
Email:[email protected]
Text/call: (850) 512-9262
Discount Code: SALE5P
Premium modified, ported, and calibrated throttle bodies.
1 YEAR WARRANTY
NEW option:
A brand new reworked part
CORE EXCHANGE option: A refurbished and reworked part shipped right after your order. Deposit and core return required.
REFURBISHED option: A refurbished and reworked part shipped right after you order. No deposit or core return required
REWORK YOUR OWN option: Ship your unmodified unit to us right after placing your order, we'll rework it in 102 business days and send it right back to you.
FEATURES:
• Optimized Active Contours with sonic flow nozzles
• Porting Taper and Upstream Bore with Velocity Stack (Lip & Bore Reduction)
• Greater Discharge Coefficient of Plate/Blade interface
• 16 Ra Microinch, Diamond Polished Surface Finish (Lower Skin Friction)
• Shaftless high-pressure side of the blade for Larger WOT Flow Area (91 mm Effective Bore)
• Self-Cleaning Throat/Flow Gap
• Dome and Thread-locked Screws
• Made from Brand New OEM Parts
BENEFITS:
• Lower weight to power ratio at part throttle, for a more nimble/spirited driving experience
• Linearization and smoothing of the curve for a more predictable response and crisper shifts
• Immediate response right off idling while keeping idling function undisturbed (No Hesitation/Stumble)
• Does not require tuning. Warranty safe.
• More air/power at every single throttle position after idle. Crucial for starting or expanding power gain modifications
GT350 - 87mm (91mm EFF.) Premium throttle body.
GT350: 2025-Present.
SHELBY GT350 - 90MM PREMIUM THROTTLE BODY (2015-PRESENT) 5.2L V8​
Ford Shelby (Mustang) GT350 (2015-Present), Voodoo 5.2L V8.
Designed and Manufactured by Soler Performance LLC,
  • CNC precision machined (Billet Aluminum).
  • Newest/Latest in TB Design & Construction.
  • Contactless Sensors (no wear on components and has a virtually endless life cycle).
  • Wide application/vehicle compatibility.
  • Dual mounting hole pattern for 80mm or 87mm manifolds.
  • Configurable for any manifold inlet size from 87mm to 90mm (included, select at checkout).
  • Porting Taper and Upstream Bore with Velocity Stack (Lip & Bore Reduction).
  • Greater Discharge Coefficient of Plate/Blade interface.
  • Dimpled shaft trailing edge.
DLX Bluetooth Throttle Controller
FEATURES:
  • Dual control, directly on the display or remotely from your smart device.
  • Ten Modes, with a total of 64 possible settings (see chart).
  • Sturdy aluminum construction, buttons, and heavy-duty harness.
  • Self-adjusting OLED display intensity for optimum visibility.
  • Real-time throttle position gauge.
  • Fail-safe vehicle-specific design.
  • Does not require the display to operate, for those who prefer a fully concealed device.
BENEFITS:
  • Controls pedal sensitivity, allowing the driver to adjust an otherwise widely considered non-linear (slow/spongy) pedal response/map.
  • Increases the sensation of acceleration/power, very important for driving pleasure in finely tuned sports cars.
  • Complements performance Throttle Bodies in achieving total throttle control as a system.
  • Plug-and-play modification.
  • Warranty safe modification.
  • Easy installation (15 min, no tools or special skills required).
Mike@SolerEngr
Mike@SolerEngr
Gold Sponsor
Alabama
Mike@SolerEngr
Mike@SolerEngr
Gold Sponsor
Alabama
Mike@SolerEngr
Mike@SolerEngr
Gold Sponsor
Alabama
Mike@SolerEngr
Mike@SolerEngr
Gold Sponsor
Alabama
Mike@SolerEngr
Mike@SolerEngr
Gold Sponsor
Alabama
Mike@SolerEngr
Mike@SolerEngr
Gold Sponsor
Alabama
Mike@SolerEngr
Mike@SolerEngr
Gold Sponsor
Alabama
