Freedom
- Feb 18, 2016
- California
- '16 GT, '22 Tesla Model 3, '22 F-150 Lightning
Foam is nice but isnt necessary. I dont see anything wrong with what he said though? except the squeegee part. But your method is the way I do my cars.Ok while I appreciate the thought here, doing it this way will end up damaging your paint. Go on youtube and look for how to properly clean a car. Here's a quick overview of what I do for a regular weekly wash. Oh...and never...ever wash your car in direct sunlight.
1) Rinse the car, get it wet. A pressure washer is great to clear off loose dirt. Then apply a ph-neutral foam, let it work for a few minutes before you continue.
2) Pressure wash the car, remove the foam.
3) Use one bucket with soap and a microfiber mitt. Clean the wheels and tires. You can use a more aggressive cleaner on the tires as long as you're careful. You can use a tire brush. When done do not reuse the bucket. Do not reuse the mitts or towels you used.
4) Get two more buckets. One bucket is a rinse bucket, one bucket has soap and water in it. Both buckets should have a dirt trap in the bottom. Also, only ph-neutral soap. Don't use soap with wax or other gunk in it. Just soap.
5) Use a fresh microfiber mitt. Get it soaped up. Start at the top of the car, apply in long smooth strokes. Never ever scrub. Never ever do circles. When wiping, rotate the mitt so a new clean portion of the mitt touches the car as you go. When you've done a pass, rinse off the mitt in the rinse bucket. Get it clean. Go back to the clean soap bucket, get more soap. Continue.
6) When your microfiber mitt gets dirty, toss it in the rinse bucket and get a fresh one. You do not want to put dirt back on the car. You should also be visually checking the mitt for dirt or debris, since scraping that back across your paint will damage it.
7) When the final wash is done, pressure wash the car and remove the last of the soap.
8) Use large microfiber drying towels to dry the car, using smooth light strokes. Do not scrub, do not do circles. If you have a low-power leaf blower you can blow dry the car first before using the drying towels. When a towel gets wet, set it aside and get a new one.
9) Open the doors, the hood, and the trunk. Use smaller microfiber towels to get all the water that got inside the frame. Water gets everywhere, and you don't want pools of water continually sitting in your car.
The next steps would be your sealant treatment of choice. Bonus points if you have a ceramic coat instead. Extra bonus points if you have a professional ceramic coat instead of a consumer-grade coat.
Then clean your microfiber towels and mitts in the laundry. Do not use aggressive soap. Use a gentle clean cycle. Do not use aggressive heat on the wash or dry cycle or you will damage the towels.
If you are willing to invest a little time and effort, you can keep your car from getting the dulled and scratched paint that you see on everyone else's cars.
Washing your paint in the sunlight is a big no no as water drys up and leaves water spots. You can get around this by keeping the car soaked and use de-ionized water.
