ahduckit
Big timin in a small town
- Nov 16, 2014
- New Mexico
- Matt
- 2015 EB mustang
It shouldn't have locked if the key was in it I would think. Unless he manually locked the doors from the door panel or another key fob.
I could've sworn that the car will still unlock for you when you touch the door handle even if the fob is in the car?
I hope it wouldn't. Having someone being able to unlock my door while I'm in the car is not appealing. Unless I am in a major accident that is...I could've sworn that the car will still unlock for you when you touch the door handle even if the fob is in the car?
I just don't see a good reason to ever take the key out of my pocket. If I need to avoid the honking on exit, I just don't fully close the door (or use the 'proximity' trick). If I am in a situation where I need the door closed and locked, I just deal with the 2 honks (or use the 'proximity' trick).Just one more reason to make a duplicate of the "emergency key blade" and hide it somewhere on the outside of the vehicle ... just as many people (like myself) have done for decades !!
Honestly thought my 6g Mustang purchase was going to be the 1st time I don't need to "hide a key", but this thread has changed my mind.
Having a spare key in your wallet works too unless you locked that in the car or just so happen to not have it with you when you need it. These are reasons I like the hidden key on the car ... it is ALWAYS there.
Doug
As you are exiting your running car, place the fob at the top right corner (when facing door from outside) of the window and then shut the door. You should avoid the honks.What's the "proximity trick"?
As for this scenario, I'd likely leave the windows open enough to reach my arms in. The car will still mostly warm up and you could leave the key inside or hold it in your hand as you shut the door.
I can't take credit for it. Someone else here 'discovered' it. I've only tried it once as I'd rather deal with the honk than take my key out of my pocket.Cool… never knew that. Thanks!
