Silly question re: FMIC install
PamAndJim
DFW
2015 EcoBoost Mustang
For guys that did it, did you test drive before putting the front end back together? I'm kinda torn because I want to make sure all is well, but at the same time as long as it's mounted, the clamps are tight and the MAFS is plugged it in should be fine, right?
Jesse R
Del Boca Vista
2015 EB PP 2003 Mach 1
Take it around the neighborhood with the bumper off..make sure it's running fine then put the bumper on..that's what I would do
Glenn G
Kaiserslautern, Germany
Glenn
15 DIB 6MT base Ecoboost
Nope, just make sure your pipes are tight and the sensor is plugged in and snug. The pipes can be tightened from the top if needs be, I just put every thing back on after triple checking and was fine.
