Signature Wheel & Cortex Racing GT500 Vertical Link Project
50 Deep
Signature Wheel Ford Rep
Gold Sponsor
Sacramento, CA
www.signaturewheel.com
2017 GT350R
The Introduction
Let me start off by saying that I am thoroughly enjoying the GT500 platform, and working with all of you on our Signature Wheel builds. Having a GT500 in hand has taught me a ton about about the little engineering changes Ford made with this car. These small nuances result in a number of changes to the way we design our Signature Wheel. That in turn has brought us to reach out to one of the most prominent names in suspension components, Cortex Racing. For those not familiar with Cortex, the owner Filip and his team have devloped components that are standard issue on the Mustang GT4. I am all about engineering solutions as opposed to leaving clients to figure it out on their own. That is the big difference between myself and others just looking to sell you a wheel. Let’s lay out the details.
The Problem
The rear knuckle on the GT500 is an entirely new piece compared to the GT350. The addition of the electric parking brake and geometry changes leaves us with a component with small changes that have big implications. For example the vertical link on the GT500 is much shorter, hangs lower than the knuckle, and uses oversized hardware. Most importantly this will have an effect on those seeking to run an 18” rear wheel for drag racing or road course use. Sam at Coastal Dyno has been the first to road test the 18” Signature Wheel drag setup, and we have already seen that without clearance-ing or replacing the OEM lower link bolt/washer that contact can occur with the wheel barrel.
The rear suspension design of the GT500/GT350 does not have a traditional upper control arm that would limit the movement of the assembly. The vertical link is used to counteract the forces of torque, braking, and other loads the car will impose upon the knuckle. That vertical link uses a softer bushing to reduce NVH, but will also have deflection occur when you impose forces upon it. Based on my discussions with Filip at Cortex it would not be uncommon to see up a 1/4 inch of movement. This can result in wheel hop or changes in the geometry until the bushing and link can control what is going on. The OEM component is rather large in size, and also uses an oversized bolt/washer. Not only is the bushing bad for performance, but combined with the size could could cause contact with the 18” rear wheels we build.
In talking with Cortex there is no structural integrity lost by trimming the OEM components to add room, but the end game is to bring about a well engineered solution.
The Solution
Work jointly with Cortex to Innovate and develop a new vertical link that checks all of the boxes. Currently most aftermarket end links are designed larger than needed to have the appearance of added strength, even if the job can be accomplished with less material or a different design. At the onset of this project we have four major goals:
  1. Develop a component and hardware that will reduce the overall footprint of the link & increase wheel barrel clearance
  2. Increase strength and stiffness by conducting finite element analysis and using stronger materials
  3. Optimize the bushing/bearing material to reduce deflection and increase overall performance with minimal increase in NVH
  4. Make it look sexy
I will be back soon with some CAD renderings of the prototype component once it is completed. A part of the puzzle we are currently missing is CAD data of the GT500 rear suspension. If any of you have some strings that could be pulled please let me know. An initial run of these will be offered as a group buy once I am able to test fit components on my vehicle and a few existing Signature Wheel Drag Pack owners.
Make sure to follow this one for updates.
June 29, 2020 Update:
The time has finally come to get these set for production. Links are 3-4 weeks away from being built, and these pre-sale units will be sold at a discounted cost of $305 shipped. Once listed on the Cortex website they are projected to be between $329 - $349 + shipping. Here the details:
- Links are CNC cut from 6061-T6 aluminum
- Anodized for durability
- Stainless Steel Spacers
- FK Spherical bearings with Teflon Liners
- Stainless steel Spiroloc Retaining Clips
- Reduced deflection
- Reduced bind
- Increased barrel to link clearance on 18" drag setups
- New hardware
- Extra Sexy
All of those using our Signature Wheel 18" drag setup will find this is going to eliminate the need to clearance the OEM vertical link or bolt.
Those interested please send me a DM with your email address.
gfcobra04
Conroe
Gary
2000 Cobra R, 94 Lightning, 2020 GT500
Will this stand up to the riggers of a road course?
Epiphany
Global
I like to disassemble things.
Superb.
T, I suppose all you really need is the center to center bolt distance and some width dimensions (at the bushings) and you'd then have the data needed to begin. I would think the same link could be used for either side but I may be wrong - I haven't looked closely or looked into part number(s). I'm also thinking it may be possible to keep a captured rubber/sleeve type bushing on the end in double shear and shrink the single shear end of the "dog bone" down where clearance is needed by using a smaller bushing/bearing and an overall smaller outside diameter of the dog bone itself where it captures the bushing/bearing. I'd be mindful of solid but articulating joints in terms of increased NVH (as you mentioned).
I do believe that you've consulted with one of the best minds in the game. I know Filip and he is extremely sharp and creative. If anyone can make this work, and in the best way possible, it's him. Smart move aligning with him on this one.
Good luck. Make it good. And hell yeah, make it sexy!
50 Deep
50 Deep
Gold Sponsor
Sacramento, CA
2017 GT350R
Most definitely. Cortex really cut its teeth in the road racing arena and has been quite successful. This will be a performance modification through and through.
Superb.
Thanks T. You can expect a couple phone calls from me as this progresses. I can think of a certain mechanically gifted person that’s worth getting the opinion of :beer:
Surfergeek
Silicon Valley
Jared
2020 GT500, 2004 Corvette Z06, 2020 F150 Platinum, 2019 Yukon Denali XL
Cool stuff. Have to put it on the list for when I get my car. Cortex makes GREAT things.
AMBJR
ALLEN
03 Mustang Cobra-20 GT500
Terrance:
I just got a set of CorTex Racing Monoball Front Control Arm Kit for my 2020 GT500; When I get it!!!
Allen
50 Deep
50 Deep
Gold Sponsor
Sacramento, CA
2017 GT350R
Cool stuff. Have to put it on the list for when I get my car. Vortex makes GREAT things.
Oh yeah. It’s going to be amazing. I cant wait for you to get the car in your hands finally.
Terrance:
Allen
Did you get your car yet? It’s a shame those parts are so beautifully made but hidden
AMBJR
ALLEN
NO!!! Not yet; I hope some time in MAY!!!
Surfergeek
Silicon Valley
Jared
Me either! With COVID Pandemic my car is delayed further, was supposed to go into production the 1st week of April, no idea now when it will hit the production line. But more important is health and safety, I can wait longer for my car.
50 Deep
50 Deep
Gold Sponsor
Sacramento, CA
2017 GT350R
I had to go out and buy another 2020 GT500 off eBay; It was a CFTP car!!!
Is this real life? Or are you messing with me?
AMBJR
ALLEN
Yes Terrance, I bought a 2020 CFTP GT500. The one I had a VIN & build date for will not be built for another 6 or 8+ months!!! I hope to have it sometime next week!!! I'll ready to buy the wheels now!!!
50 Deep
50 Deep
Gold Sponsor
Sacramento, CA
2017 GT350R
Yes Terrance, I bought a 2020 GT500. The one I had a VIN & build date for will not be built for another 6 or 8+ months!!! I hope to have it sometime next week!!! I'll ready to buy the wheels now!!!
What a freaking score! Congratulations to you brother. Please send or post some pics when you can
50 Deep
50 Deep
Gold Sponsor
Sacramento, CA
2017 GT350R
Progress is happening... check out some of the modeling for the production vertical link. Unlike other links on the market this design will increase wheel to barrel clearance on the 18” rear drag racing setups. As well as the benefits of decreased deflection, and increased stability for track use.
The design is currently omni-directional so you can install either way as long as you put the spacers/washers in the right location. It will also eliminate the oversized washer used on the factory lower vertical link bolt, adding additional clearance.
Next step is to 3D print a test piece to try on my car before production.
Epiphany
Global
Filip is a very sharp guy. Just the one to ensure this is done right.
