s650 exahust on a s550?
neomadeit
California
Neo
10r80 fbo
I have a guy selling 2024 corsa extreme active exhaust I was wondering if it would fit my 2019 mustang gt.
I'm guessing it fits but I just want to double check before purchasing.
skinnyb
Knoxville TN
Alex
21 Mach 1. FJG, Tremec, ESS G3X
SInce it's active yes it should fit pretty well. No promises though..
MAGS1
Somewhere in Middle America
Mark
2022 Mustang GT
Hangers are slightly different as I understand it. If you can get those to work you should be good
LethalPerformance
Fl
2020 Shelby GT500 CFTP, 2021 Whipple'd F150
It won't work as the active exhaust valves on the S650 are clocked completely different than the S550.
We have plenty of new Corsa systems in stock for the S550. Just create an account on our site, login and you'll see your Lethal loyalty pricing on any of the systems we offer from them.
Let us know if you have any other questions.
Thanks!
MAGS1
Mark
2022 Mustang GT
Thanks!
Is that orientation change due to the rubbing issues with the harnesses on the passenger side of S550’s?
LethalPerformance
Fl
Can't really say for sure. All I know is that the motors and valves are clocked different on the S650 which is why the S650 active kits won't work properly on the S550.
This is why every manufacturer of the active kits for the S650 were all redesigned.
Deleted member 69311
Guest
Many people online said you can’t put a 2018 GT350 exhaust on a 2018 GT… I bought one and turns out it fits just fine. Take the risk and buy it. If it doesn’t fit, ask some shop to re-weld the hangers.
LethalPerformance
Fl
How did you make that work when the connection point at the front of the system is a different size from the GT to the GT350?
neomadeit
neomadeit
California
Neo
10r80 fbo
Thanks!
Dam! One of the main things I was going for was the active exhaust to quite the cold starts. I’ll order a s550 model version instead for sure from you guys thank you!
Guest
I do have headers and midpipes so maybe that’s why it worked? The GT350 X pipe was a bit bigger in diameter (3inch to 2.75 on the midpipes) so it slipped over it. I had it sealed and welded for $100.
