S550 Lap Times (Road Course)
Teezlr
Nashville, TN
www.JakeTiesler.com
Jake
2021 Mach 1 HP - 2000 Land Cruiser - 2001 Sequoia
:headbang:
Josh H. was the one driving. This was his 2nd time at BW 13CW :)
2:00 and sub 2:00 @ 13CW at Button Willow is moving out, usually as fast as the 911s, GTRs, etc. thats awesome! Can't wait to get mine out there :cheers:
kkakonn
Los Angeles, CA
2015 GT Premium
Make/Model/engine/trans/packages: 2015 GT w/ PP 6spd
Track/Course: Buttonwillow 13CW
Best Lap Time: 2:00.03
Brake Pads: stock
Tires (Size & Model): Apex 18x10 EC7 Hankook RS3 285/35/18 SQUARE
Suspension: SWIFT Lowering Springs on oem dampers
Other Mods: N/A
Track/Course: Chuckwalla CCW
Best Lap Time: 2:05.1
Brake Pads: OEM
Tires (Size & Model): STOCK PP Wheels/Tires
Suspension: OEM
Other Mods: N/A
Track/Course: Buttonwillow 13CCW
Best Lap Time: 2:04.3
Brake Pads: OEM
Suspension: OEM
Other Mods: N/A
Track/Course: Buttonwillow 14CW
Best Lap Time: 1:56.6
Brake Pads: OEM
Suspension: OEM
Other Mods: N/A
So close to sub 2 at buttonwillow! Bet that was killing you !
Todd15Fastback
Atlanta, GA
Todd
2015 Mustang GT PP Fastback
Brake Pads: stock
Other Mods: N/A
Awesome run at 2:00!!
Curious if you know the rates on the SWIFT springs?
info@trinityautosport
Anaheim, CA
2015 Mustang
Fronts are 279lbs and the rears are 782 lbs. We have JRZ RS Pro's on the way.
Anyone going to AAA Club in Fontana on the 20th? We will be there sponsoring Bimmer Challenge. We are hoping to get the Pony Challenge going this year as well.
Todd15Fastback
Atlanta, GA
Todd
Thanks! I found the info on the SWIFT springs on their site.
So the fronts are a good bit stiffer than the stock GTPP springs but just a tad stiffer on the rears.
valentinoamoro
US
15 TY Mustang GT
What is the weight savings of these over OEM PP?
Brent Dalton
Sua Sponte
GA
2016 Mustang GT PP
Make/Model/engine/trans/packages: 2016 Ford Mustang GT base w/ PP
Track/Course: COTA
Best Lap Time: 2:32 via data
Brakes: stock performance package calipers and rotors, Carbotech XP12 front, XP10 rear pads, Castrol SRF fluid
Wheels: Apex EC-7 18x10 squared
Tires : (295/40/18 all four corners, Hoosier R7)
Suspension: aFe/pfadt coilovers and sway bars, stock bushings, links, etc...
Other Mods: Kognition wing and APR front splitter, borla ATAK with resonator, engine all stock.
Here is a video from the first session Sunday Morning warming everything up. There are some 36's and 37's in there:
[ame]
I took it easy on Friday and saw how the car was going to do. Made some minor tweaks. Saturday was mostly the same. I got sucked into lead follow with a friend on Saturday and his AIM showed several 2:32's. I figured I could warm everything up on Sunday morning and by mid day try for a 2:30 flat. I ran the first session and warmed the car and brain up. I parked the car for only 20 minutes and then went back out. As I just wanted to work on a couple turns. About 15 minutes into that session, I got a "rear axle differential temperature increased, reduce speed" warning. Score one for the 2016 mustang now that they have the temp sensors in the diff stock! My fault, I wanted to see how the stock fluid would do. I'm sure if I would have let the car cool down more between sessions I wouldn't have had the issue. I had a 12 hour drive home, so I decided not to push my luck. Hopefully the warning pops up before you cook the fluid. Diff did fine on the drive home and didn't make any noise so I assume it didn't cook the fluid. Will change all fluids in the next day or two. Thought it was worth mentioning though. My attempt to do a 30 flat will have to wait until next time. Such is life. I still had a blast. :)
valentinoamoro
US
15 TY Mustang GT
Track/Course: COTA
Is the rear diff temp sensor not available stock on the 15's?
apex15stangPP
PHX, AZ
J
2015 Mustang GT PP
Nice! Still loving that mic! Makes the video, gotta get one
Brent Dalton
Sua Sponte
GA
2016 Mustang GT PP
Not sure. I've seen a couple of threads with 15 guys saying they didn't have them. May have just been the model? Does yours have one?
ForTehNguyen
Houston, Texas
15 GT
and no issues at the track with lockouts, misaligned gates etc?
