Running Open Headers
kcc0521
Falls Church VA
Bo
2015 Black GT PP
Has anyone tried running their car on open headers? I am thinking about taking my exhaust off to drop some weight and try for low 11s. I am curious if it will help and if tune updates are needed.
GSLSE20B
Fair Oaks , Ca
16 SHADOW BLACK GTPP
You will lose a bunch of torque and maybe gain .5-1 lb/minute at the peak
beefcake
Bethel
2018 Ford Mustang
i'd at least run through the midpipe,
kcc0521
Falls Church VA
Bo
2015 Black GT PP
I may take the car there on the trailer and try it out. I could ditch the tail pipes to drop some weight.
Reds197
KC
18 BASE (sold)16 LPF 62mm 16 Whipple 15 VMP MT-82
Pull the passenger seat if you haven't already. Probably more weight savings and takes 2 minutes.
GSLSE20B
Fair Oaks , Ca
If you have an XPIPE midpipe , run open after the mid pipe . You will keep the scavenging effect and the torque .
MaskedRacerX
Driver
Vilano Beach, FL
DT
'21_JWS4XE / '21_TM3P
Seems like a lot of heat right under the car, near wiring, etc.
Years ago I installed some (LPE) LTs on a Corvette I owned, I took it for a drive for fun, without the mid/rear section of the exhaust installed - it was insanely loud (too much for me, YMMV), but the real issue is is smelled like oil, rubber and plastic burning.
Terminator2
Spring Hill Florida
David
2016 Mustang GT Premium
Keep at least 3ft of midpipe otherwise you will loose a ton on low to midrange torque. Gains will be minimal unless you have restrictive mufflers on the car.
CCCP1999
CHAS
2015 GT
It will wake up every cop on the road.
ScottsGT
Lake Wateree, SC
Scott
2015 GT, DIB
You'll probably get fresh air hitting the O2 sensors throwing mixtures way off. I had those problems with my pushrod 5.0 with long tubes and F.A.S.T. FI system. Never could get it to run right until I closed up the exhaust system.
Cascadia_302
PNW
2015 RubyRed GT M6 Premium
Terminate it at the mid pipe, then do a "ghost cam tune" and make a video.:headbang:
kcc0521
Falls Church VA
Bo
2015 Black GT PP
Does anyone know where to buy cheap turn downs that will fit the ARH XPIPE?
