rpm issues
huntiez
ca
2017 gt white diamond pearl six speed pp
So waiting for tuner to get back to me basically running new motor d1sc duel disk clutch talking to tuner now to see if we can figure it out but basically the car hits 5500 and instantly kicks back like it hit a governor no dtc no light no indication
that theirs a issue it does have gt350 phasers built sleeved blocked ported heads u know new setup so problems happen
just trying to figure this one out any advice would be greatly appreciated
sigintel
Ray
2018 GT
Scan for codes in case one is latent but not showing CEL.
Look for a cam sensor or phaser related error?
Not saying this is your issue:
There is an oil restriction orifice in the heads.
It is different in GT/GT350 heads
Are you running GT350 oil pump? or GT? or track variant pump?
You are running GT350 phasers or upgraded GT phasers?
Which exact part number?
Somewhere on FRPP I think I have seen a note about the combos of which oil pump and which restriction orifice to use in conjunction with which oil pump and/or phasers. Cant recall which dependency takes priority in determining which orifice/restriction to install.
Oh yea, the restriction might be on the firewall side of head, oh joy...
Could be other things...
huntiez
huntiez
ca
im assume stock retrictor high flow oil pump tho and im running the ford performance upgraded phaser for the the coyote so should of been plug and play
huntiez
huntiez
ca
and no dtc no matter how many time I hit that thing I don't really want keep hitting it
huntiez
huntiez
ca
whelp figured it out no belt equals to much drag for the motor to break over 5500 and ecu pull power so broke my belt from being a little two loose but yeah she back
