No, just the regular ABsRoush quad tips?
There really is nothing to break inside the AB. It's pretty much just a straight pipe.No, just the regular ABs
When you squeeze the can front to back, the noise stops. It's most likely the pipe broke loose inside the can.There really is nothing to break inside the AB. It's pretty much just a straight pipe.
You sure nobody put something in there? There is a gap that small rocks can fall into.
Agree. The roush AB is not as simple as a muffler delete pipe. It is still some form of muffler with an internal baffle. That is the weak point actually.When you squeeze the can front to back, the noise stops. It's most likely the pipe broke loose inside the can.
The welds around the ends of the mufflers were rusting, not the stainless. I know mine did it. They should have come with a weep hole drilled in them, but it was an easy enough fix to do.rusty stainless uh lol
