acm543
When I start the car, doesn’t matter if I leave it off for 5 minutes or if it’s a cold start, the rpms idle really high and real low. That’s anywhere from 1,200 down to almost 300. Then it once it calms down, it will fluctuate between 900 and 300. Also lambda b1 and b2 fluctuate all over the place. That is also any where from 1.15-0.50. After I let the car sit for a minute or two it calms down and is fine to drive. Nothing changes and the lambda sits at .93 unless I’m engine braking. I don’t know if it matters too much but while I’m driving the AFR doesn’t change from 14 on the gauge cluster on the dash board. I’ve tried cleaning the MAF sensor. My next thought is the O2 sensors. A friend mentioned it might be a plugged injector. Im going to see my tuner on Monday. Any thoughts from you guys?
. And please give a follow up after it is resolved so others can learn form this as well.
