TURTL3
It's making your downshifts smoother, hardly defeating the purpose!When you guys rev-match downshift do you guys let off the clutch pretty fast? This is my first manual car and after countless harsh over and under revving tries I found that letting off the clutch a little slower helps make the downshift smoother but not sure if doing it that way is defeating the purpose of rev matching?
The clutch isn't a on/off affair. You're matching the speeds of the transmission and the engine. Unless you rev match at the exact perfect RPM every single time (impossible for a human), you'll need to modulate how fast you let off the clutch based on the situation. If you slowed down your clutch action and you're getting better rev matching results, you're on the right track my friend.
