Removing roller followers?
dbranger94
Indiana
Daniel
Magnetic 2015 GT
Well, I'm pretty sure I have a bad roller follower on cylinder 5. I think its the one on the rearmost intake valve. It's really hard to tell by looking, so I thought I'd replace all the followers on cylinder 5 and maybe 6 to be sure. I read that it may be possible to remove the followers from these engines without removing the cams. It would appear that if you could compress the valve a bit with the piston down in the cylinder the follower might slide out.
Anyone done it? Is there a tool or something?
Anthony 05 GT
Northern Harford County Maryland
2005 Mustang GT, 2015 Mustang GT Premium
You need a proper valve spring compressor for this particular valvetrain. I have one for my 3-valve engine which works well and it's pretty easy to replace a follower using the tool. I believe I bought it at the Ford parts dept.
Reds197
KC
18 BASE (sold)16 LPF 62mm 16 Whipple 15 VMP MT-82
Get the tool and its possible. I replaced every valve spring w/o removing cams.
Anthony 05 GT
That's a cumbersome job. Leaning over the fender for hours takes it's toll even on a good lower back.
dbranger94
dbranger94
Indiana
Daniel
Magnetic 2015 GT
I was able to remove the intake cam caps and all 4 bolts from the front "mega cap" (or whatever its called) and rotate the cam out from the head enough to remove all the adjusters and followers on that cam. I ordered all new followers, but I'm starting with the DS intakes and going from there.
