Recommended Front Wheel Size (Michelin PS4S)
Fenrir
North Carolina
Chris Brown
2020 GT Mustang Premium Supercharged
Currently running stock 265/35/19 (width 9) and 315/35/20 (width 9.5). I am wondering if I can go up 275/35/20 front with no fitment or rubbing issues. Currently at the Michelin PS4s for the new tires
Fenrir
Fenrir
North Carolina
Chris Brown
Robvas
I believe I my 315s on on 10s
NightmareMoon
2016 Mustang GT PP w/ Voodoo
I'd like to see how your tire guys like mounting a 275R20 on a 9x19" wheel. I expect there gonna be some issues getting the bead to seat.
Fenrir
Fenrir
North Carolina
Chris Brown
I double checked my measurements and my front measurements are 20 Ă— 9.5 and rear is 20 x 10.
Would the 275 35R20 fit in your opinion?
NightmareMoon
Yeah that should be a good fit for the front. What are you going to run on the rear?
Fenrir
Fenrir
North Carolina
Chris Brown
I am currently running 315s and thinking of putting 305 35R20s as the 315s are almost too snug on the rear wheel well
NightmareMoon
A 10" fits a 285 well. A 295 is a little pinched on a 10" wheel.
A 315 is slightly pinched on an 11" wheel and work best on an 11.5" or ideally a 12" wheel.
Fenrir
Fenrir
North Carolina
Chris Brown
Is 305 still good to use as I am going for a staggered setup?
NightmareMoon
It depends on if the tire has a soft sidewall or not. Pinching a soft tire like a continental or 555G2 can be worse than running a more correct size. Some stiff sidewall tires will be ok. Of its too soft sidewall and on a narrow wheel the tire can cause sway.
