I thought the BMR kit dealt with the sub-frame deflection and alignment, the Steeda kit just stiffened up the diff mounting bushes within the rear subframe but has nothing to do with the subframe alignment ..... the diff is bolted into the rear subframe, so the two mods are complementary rather than one replicating the function of the other. The Steeda inserts basically keep the diff centred and stop it from wa:censored:king around under load, but this has no impact on subframe (and hence rear wheel) alignment.Thanks Andy. Useful video, especially the tip about cleaning the bolts and threads of loctite.
So the Bmr lock out kit and the steeda alignment bushes ultimately tackle the same sub frame alignment issue by the looks of it. What advantages can you see in the Bmr solution vs the steeda solution? Looking at your misalignment beforehand has convinced me to do this job.
Thanks for the feedback. From what I can see of the BMR lock-out kit it works by a) aligning the subframe by means of the sleeve on top of the large front brackets and b) by constraining the horizontal movement of the subframe by capturing the rubber bushes (front and rear) from the outside.The Steeda subframe alignment kit, is just simple bushes, that fit up into the SF mounting holes.....it will put it in the right place, but still relies on the original brackets to keep it there......
I wouldn't have bought these if I'd thought about it a bit more, but they did come in handy....![]()
To be honest, I'm not really a fan of telling others what they should and shouldn't doYou've got me second guessing whether or not to get the Steeda bushes fitted this Wednesday. I just don't know now![]()
