Rear Sub Frame Torque Settings
Eclipsar
UK
NFG Mustang GT
Any one know rear sub frame torque settings, or where to find them?
Enoch
UK
Andy
Guard 5.0 (Auto) Fastback, Saddle Leather
Rear Suspension
Front Inner lower control arm bolts (24mm): 166 ft/lbs.
Rear Inner lower control arm bolts (24mm): 184 ft/lbs.
Outer control arm bolt (21mm): 203 ft/lbs.
Upper Shock Bolts: 66 ft/lbs.
Lower Shock bolts (15mm): 35 ft/lbs.
Main Cradle Bolts (21mm): 129 ft/lbs.
Front Cradle Bracket Bolts (13mm): 41 ft/lbs.
Rear Sway Bar Mount (13mm): 24 ft/lbs.
BMR Rear Sway Bar Mounts (13mm): 24 ft/lbs.
BMR Rear Sway Bar Thrust Washers (3/16" allen):
Sway Bar End Links (15mm / 18mm / 6mm allen): 85 ft/lbs.
BMR Sway Bar End Links (19mm / 14mm): 85 ft/lbs.
BMR Sway Bar End Links Jam Nuts (19mm):
Rear Swaybar Endlink Brake Hose Mount (10mm):
Vertical Link Upper Bolt (15mm): 81 ft/lbs.
BMR Vertical Link Upper Bolt (19mm): 81 ft/lbs.
Vertical Link Lower Bolt (18mm): 129 ft/lbs.
Toe Rod Inner Bolt (18mm / 21mm): 129 ft/lbs.
Toe Rod Outer Bolt (18mm): 129 ft/lbs.
BMR Toe Rod Inner Bolt (22mm x 2): 129 ft/lbs.
BMR Toe Rod Outer Bolt (22mm): 129 ft/lbs.
Camber Arm to Knuckle: 76 ft/lbs.
Camber Arm to Subframe: 85 ft/lbs.
Rear Caliper bolts 24ft/lbs 32Nm.
Others if required...
Mustang torque specs
Front Suspension
BMR Camber Bolt (18mm / 21mm): 125 ft/lbs.
Factory Upper/Lower Strut Bolt (21mm / 24mm): 184 ft/lbs.
Upper Strut Mount Nuts x 3 (15mm deep): 46 ft/lbs.
Brake Caliper Bolts (15mm): 85 ft/lbs.
Sway Bar End Links (18mm / 17mm): 85 ft/lbs.
Front Sway Bar Mounts (18mm):
BMR Sway bar Mounts (10mm allen):
Front Lower Control Arm (24mm): 164ft/lbs
Cowl Extension (Upper K brace): 26 ft/lbs.
Strut Tower Cross Brace (15mm deep): 41 ft/lbs.
BMR Front Subframe Chassis Brace Rear Bolts (1"): 100 ft/lbs.
Inner Radius Arm Bolt (24mm):
Tie Rod to Spindle (18mm):
Steeda Extreme G-Trac Brace Front (10mm allen): 60 ft/lbs.
Steeda Extreme G-Trac Brace Rear (22mm): 60 ft/lbs.
Body/General
Oil Drain Plug: 19 ft/lbs
BMR Jacking Rails (15mm): 63 ft/lbs.
Lug Nuts: 148 ft/lbs.
Front Exhaust Clamp: 35 ft/lbs.
Exhaust Hangers: 18 ft/lbs.
Windshield Wiper Pivot Arm Nuts: 26 ft/lbs.
Negative Battery Cable: 44 in/lbs.
Transmission Cross Member (18mm): 85 ft/lbs.
BMR Driveshaft Loop (3/8"): 40 ft/lbs.
Front Belly Pan (7mm):
Steering wheel bolt (24) 35ft/lbs
Eclipsar
Eclipsar
UK
NFG Mustang GT
Thanks mate :thumbsup:
CharlieC
Letmeinok100$
Charlie
2015 Mustang GT
Please update:
Transmission crossmember to chassis bolts are 46 ft-lb.
Someone is going to have a bad day trying those at 85.
