1. NOTE: Tighten the wheel bearing and wheel hub bolts in a cross pattern.
Position the wheel bearing and wheel hub and install the 4 new wheel bearing and wheel hub bolts.
Torque: 98 lb.ft (133 Nm)
2. Install the brake disc.
3. NOTE: Apply the brake to keep the halfshaft from rotating.
Install the new spindle nut.
Torque:
Stage 1: 98 lb.ft (133 Nm)
Stage 2: 45°
4. Install the wheel and tire.
I think it's a 32mm. It's been a while though.any idea on what the spindle nut socket size is?
Other way around I think.Rear is 36mm. Front is 32mm.
I take that back. it is 35mm for the front of my eco and 32mm in the rear.Other way around I think.
