Rear Differential Pinion Seal
Bahndvr
Bahndvr
Roushcharged
Germany
'16 Roush Warrior Mustang
What size is the nut? I want to make sure I have a socket for it.
EDIT: Chilton just says to remove and discard Pinion Nut. Odd it doesn't give the size.
Bahndvr
Bahndvr
Roushcharged
Germany
Not Metric, okay thanks
Anthony 05 GT
Northern Harford County Maryland
2005 Mustang GT, 2015 Mustang GT Premium
Oh it's metric, but the SAE size will fit
Bahndvr
Bahndvr
Roushcharged
Germany
28 mm - 29 mm
Jay-rod427
Kansas
2016 GT C/S
You can't set the crush sleeve preload without an empty pumpkin. The extra force to turn the axle's and tires will give a false reading and will be set too loose. Like a few others said do NOT replace the crush sleeve, and index mark the nut to put back exactly where it was. Also you don't need the fancy pinion holding tool as you won't be taking apart the gear set. Just set the e-brake, and it won't turn so you can loosen/reinstall the pinion flange nut.
347CobraII
iowa
2015 GT
After going back looking through Ford manual figured out what it is and yes it can be reused. It's not crush sleeve as we know for old 8.8. It's preload sleeve where you torq pinion nut to spec and check preload if out of spec you replace it. Since it's not crush sleeve over torqueing pinion nut will not tighten up preload. They use this system on wheel bearings on big trucks or LMS hubs
Stress50
Stockton
2020 mustang gt
What location would this be and cause this leak I have on my diff
Justgonna send it
NC
Ty
2019 GT 6spd ess G3 kit 120mm pulley , wendgerd tune & 2020 hpp eco
Is there a seal kit that can be purchased or will i have to get all the parts seal etc. separately? Also whats a good fluid to put back into pumpkin ?
Skye
≈39N
"Skye" Mach1 N2144
Justgonna send it
NC
Ty
Skye
≈39N
"Skye" Mach1 N2144
I have never seen a seal leak/light drip at 30k.
I recently had the left axle seal replaced with fewer miles. My current thought process is it is not necessarily the seal/s, but the assembly process.
Documentaries I've seen, workers have moments to put-together things I could easily blow several hours on. I feel seals getting nicked, seated unevenly before tightening, etc, could have something to do with. It's just a thought.
Good Luck in the repair. :please:
Justgonna send it
NC
Ty
Yea What’s crazy it a 2020 HHP eco. That’s not really beat on. hell i think it was starting to leak at like 15000 or 20k i just thought it was something she picked up off the highway.
