WD Pro
- Jan 18, 2018
- United Kingdom
- Lime GT
- Vehicle Showcase
- 1
One set of stainless steel bolt sleeves to reduce the gap between the standard M14 diff bolts and the piss poor fit rear subframe bushings.
More info about these items and their purpose can be found here :
https://www.mustang6g.com/forums/th...al-mount-bolts-issues-resolutions-pics.74891/
Donāt think that just the high power or abused cars would benefit from these, hereās what happened to mine :
Even the side that didnāt break a bolt had moved and was starting to chew the bush :
I now have a set of these sleeves fitted to my car, they will work with standard bolts or upgraded hardware (unless you have already done the M16 bolt mod) :
The sleeves I have for sale increase the bolt diameter in the bush bore to 16mm.
The sleeves I have in my car are 17.2mm which is a push fit, but (according to my tech) made fitment tricky as everything needed to be lined up perfectly to get the bolt started as there was zero wiggle room.
The picture required to keep me on the right side of the moderatorās :
Ā£15 posted in the U.K.
WD
WD
