Rear clunking noise after lowering
Oahu, Hi
Matthew
2019 GT CS
I just changed out stock springs to eibach pro lowering springs, I am hearing a clunking noise in the rear suspension at low speeds. I torqued down all the bolts that I touched to specs, but I’m still getting the noise. I’m thinking the springs aren’t seated correctly but I made sure the spring bumpers touch the notch on the lower control arm ? This is really getting me heated every time I drive! Can someone please help me !! Thank you in advance
Oahu, Hi
Matthew
2019 GT CS
I’m also wondering if I have to get another alignment is I do adjust the springs but only in the rear !
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
Dominant1
Dr Frankenstang
No
Adamone92
California
Adam
2022 Mustang GT PP Premium
Check to make sure your rear swaybars are torqued to spec too
..stiffler..
Sackville
Spencer
2020 gt convertible
Did you figure this out?? I'm getting a clunk as well..
GilmourD
Rutherford, NJ
Tom
2016 Mustang GT/CS - Ruby Red Metallic
Does it sound kinda like an impact wrench hitting the underside of your floorboards?
I've been under the impression that the sound I'm hearing in my car (which I purchased already lowered) is the exhaust,which seems like it was installed by a welder-happy Stevie Wonder for a multitude of reasons, including one of the clamps mounted with the nuts facing upward and WELDED TO THE PIPE. One of the reasons I hit up @beefcake for a new exhaust which should be shipping soon.
If it's not the exhaust clamp banging on the underside of the car, I'll be watching this thread for your solution.
