Raxiom unit issue
Miichaelo912
Houston tx
2015 mustang v6, 2017 mustang gt
The buttons that have the arrows, rewind, fast forward and ok button don't properly function right unless I press them a little harder than normal. 2 of them (rewind and down) get stuck. Has anyone have this issue before? If you have, did you fix it and how? Tech support said it's the 4 screws in the back.
zackmd1
Zack
I had the unit and found that the included rubber pad that goes behind the buttons to be subpar. In extreme heat the buttons will not function properly. I suggest you modify your OEM button pad to work with the new unit.
Miichaelo912
Houston tx
Okay I'll keep the in mind. The tech support said it could be the 4 screws
Cerberus
Los Angeles
2016 Mustang Ecoboost (Magnetic)
If you watch the Rosen installation video, he specifically has you skip some of the screws, and cautions against tightening the remaining bezel screws, too tightly. If not done properly, the buttons can stick or not function at all. Good luck.
SpeedLu
some swamp
2020 Premium PP1 Mustang GT, 2017 F-150 Platinum FX4
Unacceptable for such an expensive unit.
