Rattling noise coming from engine?
JT1652
El Paso, TX
2016 GT350
I took my 16 Gt350 to a dealership for the oil line recall. A few days after getting the car back, I noticed this rattling noise. Any thoughts?
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
Did you check the oil level ?
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
Yes, the oil level is good. I forgot to mention that it does not make that noise until the engine warms up.
Sounds like valvetrain noise, i would bring it in ASAP to have it diagnosed.
Could be a bad valvetrain component or something.
cosmo
Michigan
2005 Mustang GT
That sounds like a bad VCT phaser possibly. It tries to shift the cam after getting up to temp and this happens.
melwff
Danbury,CT
2021 Mach 1 M2486
did they change the oil and put in the wrong oil?
stanglife
Jeff
1993 Coyote Coupe
Did you leave the car with them? Document the mileage in and out?
When I read the title, I thought, "great, another piston slap thread."...but that's definitely not piston slap (which is normal for these cars).
Do the same video again and just tip in the throttle a bit off idle....well - maybe my first suggestion should be to get it to the dealer ASAP.
North Texas
Charlie
2016 GT 350 Ox White OTT blue stripes, tech pack
Engine rattle
I had a similar "rattle " when My car was new. A bolt/ push pin securing the oil cooler lines was left out dealer corrected the problem. When I had the recall applied the same service manager who corrected the first problem installed the new oil lines and insured the push pin was installed. Worth checking.
JT1652
El Paso, TX
2016 GT350
I got the car back from the dealer. After the oil line recall was completed, the engine cover on the bottom of the car was not secured properly. This was the cause of the noise.
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
Happy ending. :cheers:
