Stage_3
Is it an update?Have you read about the no cost mods to improve the sound of your B&O system?
Nope, just a member who did some outstanding work and passed it on.Is it an update?
I tried the recommendations above and find the B&O system to sound very good. If you play XM, it's OK. Now put in my thumb drive with some decent digital files and the difference is noticeable. XM is not even close in sound quality.Nope, just a member who did some outstanding work and passed it on.
https://www.mustang6g.com/forums/threads/how-i-improved-the-b-o-sound-quality-for-free.141052/
I like the B&O system.
I cancelled SiriusXM. I’ve had it on and off for a few years but had enough and cancelled for good. Giving Spotify another try.That's because XM is overly compressed garbage. Tight bandwidth and too many channels.
yeah sometimes they give you deals for the XM, however I don’t see a need for it... I pay $10 for Apple Music. The only benefit I see I for the XM is sometimes the stations gives me new songs I haven’t heard that I hunt for on Apple Music...I cancelled SiriusXM. I’ve had it on and off for a few years but had enough and cancelled for good. Giving Spotify another try.
I absolutely hate the double horn honk when you leave the car and close the door with the engine running. It seems like most if not all Ford cars do that and I don't know if there's any way to disable it.I've only had mine a very short time, but at the moment, it's no power tilt. The Premium should come with memory seats and power tilt w/o having to get another package and then just getting the memory seats. I could have the #2 memory setting in my 2011 G37 set for the seat all the way back and steering wheel all the way up, then the #1 setting for my preferred seating and steering wheel position. Much easier to get in and out of a low sitting coupe when you have that capability. Then with the design of the manual tilt/telescope, it's a poor design. It takes a good amount of force to undo it to tilt upward, then because the arm hangs down you can't get out w/o busting your knee, unless you push it back up to hold it. So entry / exit pretty much sucks. Then the cooled seats seem to freeze your arse, but doesn't cool the back much if at all, which is what I'd prefer it to cool. Then the 10A wants to climb to the highest gears too soon. I have to experiment more with leaving it in Sport and not using the paddles, to see if that gives me more of what I want. Lastly, is the dreaded double horn honk if you leave the car with it running, shutting the door with the keys on you. Highly embarrassing. But with those nit picks... I'll live.
You can shut that off in your settings..I absolutely hate the double horn honk when you leave the car and close the door with the engine running. It seems like most if not all Ford cars do that and I don't know if there's any way to disable it.
Only with Forscan though, not in any car menus. Eventually I'll probably do that but I haven't had a working laptop in years now, and the phone version of ForScan is pretty gimped.You can shut that off in your settings..
https://www.mustang6g.com/forums/th...get-out-of-the-car-while-it-is-started.82103/
Yep. I tried it when another forum member said it did nothing, and same thing with my 2019 Bullitt. Unchecked the DRL box under the lighting menu, and absolutely nothing happened. Same intensity, and they're always on with the ignition on. Wonder what the hell is that box for then. I like those tri-bars, so not an issue for me, but makes no sense to have a box and not doing anything.Also is there a way to turn off the Tri-bar running lights? I see a setting for daytime running lights but it doesn't seem to be for the Tri-bar lights.
They're always on as accents, kind of like how the Golf GTI/R have them. DRL is just for the main lamps but driven at a lower voltage.Yep. I tried it when another forum member said it did nothing, and same thing with my 2019 Bullitt. Unchecked the DRL box under the lighting menu, and absolutely nothing happened. Same intensity, and they're always on with the ignition on. Wonder what the hell is that box for then. I like those tri-bars, so not an issue for me, but makes no sense to have a box and not doing anything.
