Ramps
FishGeek
Boise, ID
Terry
'15 Mustang GT Premium - Guard Metallic
Anyone know where/what kind of ramps I could get for a '15 with Performance Package?
I do a lot of the work on all my other cars but the vehicle ramps from the autoparts stores tend to be too steep to allow use with lower vehicles.
Last time I worked on the Volvo, I had to drive it up on 2x4s in order to get the clearance I needed.
I do have a floor jack but depending on placement even it either doesn't fit well or the range for the lift handle is severely restricted until it is almost all the way up.
FishGeek
Boise, ID
Terry
Awesome thanks! You aren't kidding about the cost...but I do like the specs, and the two-piece model looks very appealing.
NvrFinished
So Cal
2016 DIB GTPP
Yeah, the 2-piece one is great for working under the car. It's what I ended up getting and I love it every time I use it. With the actual ramp part out of the way it makes for easy access to stuff under the car.
Tobey
16 Vert
I have Rhino Ramps that work just fine with my base v6. High enough for oil changes and such.
Same here, never had an issue with Rhino ramps
ForTehNguyen
Houston, Texas
15 GT
rhino ramps are fine on stock height, if you are lowered you have to use wood blocks to get up or use race ramps.
Berstuck
Northern California
Brien
2015 Ecoboost Premium PP M/T Competition Orange
I'm lowered and can still drive up on my 44" race ramps, although it's close.
Laztug
Wanna run dyno slips bro?
COTUS
Calling out OKC #1 spot after axle back install.
Paying for the race ramps was the only time I was unhappy with my race ramps.
shobbs007
Forensicator
Mt. Juliet, TN
2015 GT - Race Red/PP; 2009 Tundra RW
Same here. They are sweet after you get over the price tag.
FranzVonHoffer
Houston
Black Mustang Base GT TP
Same here, I'm lowered 1.5" and had to cut two 3/4 inch plywood squares to lift me just enough to get my chin splitter over the ramp channel.
69mach1-395
central nm, usa
2016 RR GT/CS
2x10s are cheap and should work with any ramps...about 2' long.
ctandc72
VA
'19 GT 6 speed Base
I've never owned a set of ramps. I don't get it...Now with the jacking rails installed, I can literally have my car up on jack stands in the time it takes to smoke a cigarette. I have a small garage too...I just take the handle extension off my floor jack and it works fine.
Maybe it's just me? :shrug:
JuRuKi
SoCaL
2016 GT/PP
for some reason i trust ramps more than jack stands. I've had my car wobble on jack stands when i was tightening nuts before and it was very very scary.
