Quick question for wheel tire experts 275 / 315
stang305
Cape Coral, FL
2015 Mustang Gt
Will 20x9 / 20x10.5 velgen wheels
With 275/35/20 and 315/35/20
Rub at all ? On performance pack gt with brembos ?
Will it have any issues at all ?
Will not be doing any suspension mods, do they need spacers?
Thanks !!!
stang305
Cape Coral, FL
2015 Mustang Gt
Bump
Paul@PKAUTODESIGN
The Wheel guy
Los Angeles, California
WWW.PKAutoDesign.com
Paul A.
2016 Shelby GT350 Tech Pack #G5531 Avalanche Grey
Fitment will work fine, rear will be adjusted to -2 degrees if you ever lower her that is all that is needed.
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
stang305
Cape Coral, FL
2015 Mustang Gt
I'm a noob could you elaborate more on what that means -2 degrees ?
Thanks
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
Thanks
Your rear is a IRS ( independent rear suspension)
what this means is the rear we can adjust the camber specs so if you lower the car ever then in that case with the 315 tire the rear needs to just have some negative camber applied.
stang305
Cape Coral, FL
2015 Mustang Gt
Is that something the person (shop) installing springs would know how to do? Or is that something done with vehicle gets aligned ?
Thanks
saf602
Illinois
2017 GT
Kind of the same question.... any fitment issues with 315 35 20 on a 20x11 +50 for the rear?
wildcatgoal
@sirboom_photography
TBD
No, I've done that. But you will need -1.8 rear camber there'bouts and potentially Steeda alignment pins if your IRS is off to the left or right.
